fft use
hello everybody,
I need to obtain the frequency content of a signal, but the occuring frequencies are propably not integer multiple of each other. If I use the FFT the amplitude is not calculated correctly (see attached vi). I guess that I'm not allowed to use FFT.vi but unfortunatly I've no idea which *.vi I have to use instead.
Can anybody help me?
concerning to the attached vi try:
ampl.1=ampl.2=1
freq.1=1
freq.2=6
result after fft:
ampl.1=1
ampl.2=0.7
location with peak detection gives also wrong values.
And second question: Does the rms identify the right values or is it also confuesed?
Thanks Claudia
Message 1 of 8
(4,184 Views)
You can use the FFT but you need to increase the number of samples. The more samples you have the closer you will get to the correct amplitude.
Randall Pursley
Message 2 of 8
(4,167 Views)
Claudia,
I would recommend using the Extract SIngle Tone Information.vi to perform the peak detection in the frequency domain. This VI is designed to do exactly what you are trying to do. I have modified your example to demonstrate.
Message 3 of 8
(4,148 Views)
Hello DSPGuy,
I can't open it because I've only version 7.0
Can you please save it in an older version?
Thank you Claudia
Message 4 of 8
(4,140 Views)
to rpursley8
if I increase the number of samples then it matches the right amplitude. But if I increase the number of samples to high then the second amplitude is to high.
In my case I don't know the occurent amplitudes and frequencies so I'm not sure that this will work out because it means to me that every frequency has a proper number of samples that I have to find. Mmh this way should be difficult, maybe there is an other one.
But thank you for you proposal
Claudia
Message 5 of 8
(4,138 Views)
Try making the number of samples and the number of samples per second the same. The simulations I ran show that the amplitudes seem OK.
Randall Pursley
Message 6 of 8
(4,134 Views)
Hi Claudia,
Sorry I missed your post earlier. Here is the VI saved in LabVIEW 7.0.
Message 7 of 8
(4,113 Views)
@ DSPGuy
thank you very much for your reply. You were absolutly right. I use it and it works really fine 🙂
claudia
Message 8 of 8
(4,088 Views)
