fft analysis problem
For example, I have a real time FFT data ranging from 0 to 300 Hz, how can I analyze the amplitude on specific frequency only, like what is the amplitude in 50 hz, 98hz etc. What will I do?!!
(2,782 Views)
Jack,
Since your question is short on specifics, I need to make some assumptions. If you are using the basic FFT function, look at the help file for a definition of the frequency bins. Some of the higher level spectral analysis VIs have a df output which makes determination of the frequency bins very straightforward.
Once you determine the frequency bin width, you just count up to the desired frequency and look at that element of the FFT array. If you have bins that are 2 Hz wide, then 50 Hz will be in the 25th bin (index = 24). Depending on what resolution you have and what kind of windowing was done, the adjacent bins may also have some of the energy of the desired component.
Lynn
(2,776 Views)
