fatal internal error : "fpsane.cpp", line 432 (labview version 8.6.1)
Has anyone seen this error?
I've tried to copy the block diagram and pasted on a new VI but the same error still occurred time after time.
I was using DAQ Assistant to set up tons of channels for measurement.  After I rearranged the scanning order and clicked OK, Labview seemed to struggle to update then the error popped up and would have to close the program.
I've spent MANY hours on this issue but don't know what to do.  I didn't see anything similar online or in this forum.  Please help....  Thanks.
(3,390 Views)
A fpsane.cpp error is a frequently asked question and the most likely cause is something got corrupted on the front panel. Check out the following: What Does an "Insane Object" Error Mean and What Should I Do?
Hope this helps.
Steve M.
(3,359 Views)
I've used this method several times and it worked every time...
http://labviewwiki.org/Insane_Objects
Mike
(3,352 Views)
