fatal error: LABVIEW.LIB was not called from a labview process
I have built a very simple executable which uses shared variables which should talk to an OPC server. When I try to run it on the target machine, I get this error. Does anyone know what it means?
(4,481 Views)
This link explains the error, why you are recieving it and how to fix the issue, hope this helps!
http://digital.ni.com/public.nsf/allkb/A4C3AEF93240280A86256931006FB66C?OpenDocument
(4,475 Views)
Thanks for the link, very helpful. I did indeed convert my project to version 8.2 from version 8.5, from reading the article it sounds as though all I need to do is a mass compile, and then all should be well?
(4,467 Views)
If you up/down graded from 8.2 to 8.5 then I would suggest doing a mass compile on the VI's into a new folder (or have a backup of your files somewhere).
You can do this via LabVIEW > Tools > Advanced > Mass Compile.
Please let me know how this turns out.
All the best,
Message Edited by rsw on 01-08-2008 07:02 AM
(4,462 Views)
I did the mass compile, and now its seems to be working fine, so thanks for the tip! I also unchecked the "enable enhanced dsc run-time support" option on someone else's advice, so I'm not sure whether it was that that helped, or maybe both things were required.
(4,439 Views)
