falling edge time determination
hi the world
______________
                            |_______________
as crudely depicted in the graph above
how can i determine the time when the edge occurs, the horizantal axe being the time axe?
i've seen functions in the 'waveform measurement palette' that calculate other caracterisics of the waveform.
thanks a lot
(2,776 Views)
If all you want to knwo is when a transition occurs, use the Basic Level Trigger Detection function on the analyze>Waveform Monitoring palette. You can retrieve either the index to the trigger point or the absolute time with the mode input.
(2,770 Views)
Smiley Happy
thanks a lot da xia !
ps: da xia means expert in chinese, in a cool way which shows full admiration 😛
(2,757 Views)
