failed installation of Lv7.0 under WinXP
I tried to install LabView7.0 under Win XP. It failed during the first part with the following message:
Error1305: Error reading from file c:\windows\system32\ninetbrw.ocx. Verify that the file exists and that you can access it.
The file exists and there is no "read only" or "archive" label marked.
Hope you know the problem, because it's urgent.
Thank you.
VK
(2,557 Views)
VK,
I am not sure whether you meant error 305 or 1305, however a good suggestion that normally help install errors is to first copy the contents of the entire CD to your hard drive and install from there.
The file in question is an activeX control. Try to register it using regsrv32. To do that go run and type in regsrv32 then the full path to the file, however an easier way is to type regsrv32 and then drag and drop the file into the run command line, which will place the path in it.
(2,557 Views)
The problem has been solved inbetween. It turned out that the cab file which holds the ninetbrw.ocx file was damaged. A different CD did the job.
Thank you
VK
(2,557 Views)
