fahrenheit to Celsius Unit dsplay LV 8.2.0
I'm using LV 8.2, the Unit labels work fine, only problem is the conversion from F to C and C to F appear to be wrong... I was expecting 70Fdeg to show 21.11Cdeg. Instead the control converts 70Fdeg to 38.8889Cdeg.
While I'm at it what the meaning behing showing degress Fdeg or degF... Is the the same conversion only the label is change?
richjoh
Message 1 of 20
(5,802 Views)
LabVIEW help (http://zone.ni.com/reference/en-XX/help/371361B-01/lvhowto/available_units_in_labview/)  says degF is absolute temperature and FDeg is temperature difference (relative)...Wish there was a more elaborate description.
Message 2 of 20
(5,797 Views)
Thanks for the link, as I see that there is an absolute (degF or degC) and the other is relative Fdeg or Cdeg. But, the LV 8.2 conversion is obviously incorrect here in the example I give above.
Anyone try this with 8.5..or 8.2beta
Message 3 of 20
(5,790 Views)
If you change the Fdeg to degF and the Cdeg to degC, 70 degF does yield 21.11 degC.
Message 4 of 20
(5,787 Views)
attached a pic, take a look and you can decide if LV 8.2 temperature conversion is correct???
regard,
richjoh
Message 5 of 20
(5,749 Views)
The degF and degC are correct.
Message 6 of 20
(5,733 Views)
Hi richjoh,
they are all correct:
Message Edited by GerdW on 03-04-2008 05:59 PM
Message 7 of 20
(5,723 Views)
I'm not looking for a conversion relative absolute zero. I looking for C to F and F to C. So your saying only absolute zero reference is done here with the LV units???
richjoh
Message 8 of 20
(5,703 Views)
I see from the link the NI chosen base unit is Kelvin. Not running a thermodynamic over here. Be nice to let me chose the base, so I'll do C to F manually as usual...
Message 9 of 20
(5,698 Views)
It is easy enough to write your own vi to do the conversion:
Message Edited by tbob on 03-04-2008 12:33 PM
- tbob
Inventor of the WORM Global
Message 10 of 20
(5,696 Views)
