facing problems in conversion
Hello Sir/madam,
Iam a newbie in labview here is a program where im facing a problem in conversion Please provide me assistance in the program.
Message 1 of 10
(3,929 Views)
And what exactly is your question?
Message 2 of 10
(3,924 Views)
actually i wanaa convert 1d array into boolean
Message 3 of 10
(3,908 Views)
actually 1d boolean array into boolean
Message 4 of 10
(3,907 Views)
You did not need to repost the VI again. Twice. You already posted in the original message.
As for your question: you can't (under any programming language). You either index out a specific element, or perform a Boolean operation on all of the elements, such as And Array Elements or Or Array Elements. Which is more appropriate for you I have no idea since I do not know what the code is doing.
Message 5 of 10
(3,902 Views)
I am trying to drive a dc motor by taking input signal from a device
Message 6 of 10
(3,884 Views)
That didn't clarify anything.
You have a 1-D array of booleans you want to convert to a single boolean.  How?  Do you want it to be True if you have all Trues in the array?  Be true if there are any trues in the array?  Do you want the first element of the array?  The last element?  What does the array of booleans actually mean and how do you want to convert that to a single boolean?
Message 7 of 10
(3,878 Views)
Yes I want it to be true if there is any true in the array,both elements to be added up .the array of boolean actually means iam accuring two signals from a device,and I. Want the value to be converted into single boolean
Message 8 of 10
(3,875 Views)
Then use OR Array elements.  It takes a boolean array, if any element is True, the output is True.  If all elements are False, the output is False.
Message 9 of 10
(3,871 Views)
Except - never, ever do an equality comparison with floating point numbers.
Message 10 of 10
(3,868 Views)
