facade is broken
When I am trying to build an exe of the program it shows the following error:
Cannot complete build because following VI loaded broken:
Open the VI in LabVIEW and fix the listed errors. If the VI loads as expected but errors are still detected during the build, contact National Instruments technical support for assistance.
Broken VIs:
- NI_Excel.lvclass:Excel Set Cell Color and Border.vi:
Contains unwired or bad terminal
- myprogram.vi:
Ability "Facade" is broken.
how to solve this issue?
Thanks and Regards
Parvathi
(1,315 Views)
Hi Parvathi,
@Parvathiiii wrote:
Broken VIs:
- Sensor Simulator.vi:
  • The RGT functions can show such errors when Microsoft updates its Office software (or you change from an older Office version to a recent version). You need to open that specific VI and handle the unwired terminal…
  • The SensorSimulator seems to be a VI of your own code base: maybe this error pops up due to the RGT/Excel error?
(1,303 Views)
is facade error also due to version missmatches?and also no issues while run the program?
(1,281 Views)
Hi Parvathi,
Now you renamed the VI to "myprogram"…
As it's your VI and you didn't attach that VI we cannot give specific advice.
I only can guess about the reason for the error and it COULD be related to the other error…
(1,277 Views)
