extracting a particular bit from bytes
Hi
Is there any inbulit VI that extracts a particular bit from  bytes ???
 i have acquired data using pattern generation method in which the port is read as a whole(i.e. 8 bits data at a time) , but i need data  from a particular bit only and then i want that data to be again converted into byte format...
can anyone help....
thanx and regards
vivek modgil
(4,764 Views)
This could be one of many ways to index specific bit from a byte data
Ian F
Since LabVIEW 5.1... 7.1.1... 2009, 2010, 2014
依恩与LabVIEW
LVVILIB.blogspot.com
(4,755 Views)
You could convert your byte to an array of boolean, extract the desired bit using logical AND and convert the array of boolean back to a number.
Regards
Jörn
(4,759 Views)
Why convert to boolean array ? You can do an and operation directly on the U8.
(4,740 Views)
I'm with Sture on this one.
a simple "AND" will do nicely.  Just add a ">0" after the AND and you have your Boolean.
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
(4,733 Views)
