extract data from txt
Hi guys
I want to plot "torque values" vs time from this txt file. My idea is to start moving data into an array starting after torque values, then doing the same to time values for a different array. I am struggling to get this specific data into an array. Can someone help me achieve this?
Message 1 of 11
(5,461 Views)
Hi hans,
this will give you an idea:
There are surely better ways to parse your text file!
(I just took the part containing the measurement data and parsed them "step by step" using plain string functions.)
Message 2 of 11
(5,453 Views)
Hi GerdW, thank you very much for the reply.
The text file is generated from a machine and sent to a pc.I have no control over the layout of the txt file. My idea is to extract the data after the word "torque" and "time". I think you copied the txt file into labview and then just worked from there, so not quite what Im looking for, but I appreciate the effort. The idea is you just click a button and Labview will extract that information (torque and time) into two different arrays, which is the plotted.
Message 3 of 11
(5,425 Views)
GerdW said it was an "idea".  Your job now is to use a little imagination to make it suit your needs.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(5,386 Views)
The whole point of the question is extracting specific data from the text file, not how to use it. Once i get the data into an array, its very easy to plot. So to be blunt, his answer helped nothing.
Message 5 of 11
(5,362 Views)
Hi hans,
Well, my idea shows how to extract specific data from text/string.
All you need to do is to load the text file and find/filter the part with the measurement data.
In your first message you did not mention any buttons so I guess you know how to display a file dialog to allow the user to select a file...
Message 6 of 11
(5,357 Views)
To put it bluntly, you definitely lack imagination.
Bill
CLD
(Mid-Level minion.)
Message 7 of 11
(5,355 Views)
Accepted by topic author hans7755
What the hell is going on here? Parsing a JSON file is not that easy.
Same developers share great code for JSON parsing.
Here is an example using JSONtext from JDP Science for your file.
Message 8 of 11
(5,348 Views)
Hi Martin Henz
This is exactly what I was looking for!! Thanks so much for the help, appreciated!
Message 9 of 11
(5,329 Views)
Hi guys, I have a similar problem. I have to extract data from the columns of a .txt and plot it. The problem is that the file does not allow me to extract more than one piece of data. What is my problem in the block diagram?
Message 10 of 11
(5,052 Views)
