extract data from from array string
I would like some help to extract the lines of code after the "CALL ZocSend" command and place the extracted data into another array file.
INPUT ARRAY:
CALL ZocTimeout 60
CALL ZocWaitForSeq 100000000
CALL ZocDelay 0.1
CALL ZocSend "prog:gpio:w:dsp_rf_reset:00^M"
CALL ZocDelay 0.1
CALL ZocTimeout 60
CALL ZocDelay 0.1
CALL ZocSend "PROG:I2C:CODECA:WRITE:0000^M"
CALL ZocDelay 0.1
CALL ZocSend "poc:powerup_config^M"
CALL ZocDelay 0.1
EXTRACTED OUTPUT ARRAY:
poc:powerup_config
Any help will be greatly appreciated.
hiNi.
(4,592 Views)
I'm not clear on precisely what you're after because there are several instances of the "CALL ZocSend" command in your file.
This will give you all the results after the first instance:
Jim
(4,571 Views)
Thanks for getting me started.  In the attached updated VI, I would like to get rid of the empty cells and have the output array with just the three enteries:
poc:powerup_config
(4,566 Views)
Much easier than that 🙂
Jim
(4,562 Views)
2012 snippet:
Jim
(4,560 Views)
You can also get rid of the quotation marks using the String Subset vi.  Set the offset to 1 to remove the first one, and set the length to be the initial string length minus 2.
(4,543 Views)
Even easier than that, and for fun with Regular Expressions, change the contents of the For Loop to this:
Jim
(4,534 Views)
