extract ROI
i am new user to vision & i am trying to extract ROI from an image. i made the code but not able to run it successfully. I am attaching my code. Please look at the code & suggest me the problem.
reply soon.
Message 1 of 8
(6,860 Views)
Message 2 of 8
(6,859 Views)
Accepted by topic author R.V.
Problems in your code:
a) race condition
b) wrong order
Andrey.
Message 3 of 8
(6,851 Views)
now i am able to run it.
thanks andrey.
Message 4 of 8
(6,833 Views)
Hi RV,
Your code is interesting.
I am attaching another code for extracting ROI from grayscale or RGB image. When i use the image in second attachment some it give invalid image. Not sure why. Could you figure out. Also, if you could see how can i "fit to window" in the ROI constrcutor pop up window since the image has to be scrolled due to its larger size. ..Thanks
Message 5 of 8
(6,788 Views)
related question:
how can i set the  ROI tol be the entire image frame?
Message 6 of 8
(6,695 Views)
how can i select roi from entire image?
Message 7 of 8
(6,589 Views)
Just select rectangular ROI which will cover entire image (ROI's width and height should be equal to image's width and height)
Message 8 of 8
(6,569 Views)
