external component modified since last VI save
Hi !!
it's been quite a bit that I'm stuck with this message "External component modified since last VI save". One explanation on the forum does not solve my problem.
The problem is :
I have a simple VI (enclosed) that I open on two different computers. Each time I save it on one computer and I open it on the second one Labview shows the mysterious message "External component modified..."... and I have to save the VI... Back to the first computer - same thing...
Does anyone know where should I search to get rid of this message ?
Thanks for any suggestions...
Message 1 of 10
(3,520 Views)
You had asked basically the same question a while ago.
You probably have two different versions of Excel on each computer. Or, you have one with a different service pack.
Message 2 of 10
(3,508 Views)
........No, I've checked that... same version of excel on both computers and same SP... any other hints ? Thanks anyway...
Message 3 of 10
(3,498 Views)
Maybe it is the difference of the operating systeme, do you use the same operating systeme on both computers? (Windows XP, Windows 7)?
Regards
Marco
Message 4 of 10
(3,487 Views)
...Same OS on both computers XP Pro SP3...
Message 5 of 10
(3,474 Views)
Ok,
What does your application do anyway? It could be a problem of the Active X Refernces
Message 6 of 10
(3,466 Views)
My application opens Excel, creates a workbook and etc and then sends a 2D array... Yes, the problem seems to come from a different component somewhere (probably in the Active X references as you said), but I don't really know where to search...
Message 7 of 10
(3,464 Views)
Do you open and close every Reference correctly?
Message 8 of 10
(3,459 Views)
Yes, references are opened and closed the same way...
In fact my problem is summarized in the VI I enclosed in my first post... There's one computer that has a different configuration from others here, and when I open that Vi on that computer Labview asks to save it before close (external component modified). I've checked the OS, the Excel version, ...
Message 9 of 10
(3,455 Views)
Do have the same Versions of LabVIEW on both Computers? (Version, Service Pack, Patch, Language, Toolkits, Drivers)
Message 10 of 10
(3,446 Views)
