expressxy
I was just curious in looking at the expressxy subvi attached, it looks as if there is an array constants with an array inside? Am I misinterpretting this because I thought this could not be done.
(3,418 Views)
Accepted by topic author GregFreeman
Ok figured it out. Thats an array of clusters. Each cluster is an array of doubles. To replicate create a numeric constant of Double precision. Put that into a array constant/container. Repeat. Take those 2 arrays of doubles and place them into a cluster constant/container. Now place that structure into a array constant/container sized up so it doesn't just lay on top.
Remeber: if you have the vi ctrl+H is your friend Smiley Wink
Message Edited by GovBob on 02-23-2009 05:57 PM
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,398 Views)
ah, thanks for  clarifying! I was just a little confused looking at first glance.
(3,376 Views)
Sweet. Thanks for solving the question.
Just as an FYI, you can have an array of clusters, a cluster of arrays. You can't have arrays of arrays. The workaround to have an arrays of arrays is to have a cluster of arrays and drop that cluster into an array.
Warm regards,
Karunya R
(3,359 Views)
