express timer is not functioning in state "running"
hi,
   I have a unfinished VI but I am trying to test cases step by step..
 in the case " running", the express timer is supposed to work, but why it simply skipped the case " running" and moves to " initialize"?
      thanks
(3,125 Views)
because in running you go to rain and then stop and then initialize...
Use the debug you will see.
You should never put a Event structure to more than one place in your code.
You should use a Producer consumer structure.
Benoit
(3,119 Views)
Thanks..
but it should finish the state "running" first and then go to the state "rain', right??
(3,087 Views)
I think you should design your application on paper to define your step... I have no idea what is your system.
Benoit
(3,066 Views)
