exporting data to a DLL file ?
Hi.
I have created a DLL file using the application builder add-on. I have to export an array continuously to this DLL file, but can't find any DLL related option in the File I/O function in block diagram. How to do it ?.
Best regards
Oesen
Message 1 of 8
(3,723 Views)
What does File I/O have to do with it? You use the Call Library Function Node if you are calling the DLL from LabVIEW. I'm not sure why you would create a DLL from a VI and then call that from another VI.
Message 2 of 8
(3,716 Views)
Thanks for the reply Dennis
The arrays has to be imported from an another user with c-code from the DLL file.
Best regards
Oesen
Message 3 of 8
(3,704 Views)
So you're just testing it. Can I assume you found the Call Library Function Node?
Message 4 of 8
(3,702 Views)
I use this VI to grab frames, convert them to pixel values and finally export the array to a .csv file. I have made this one for testing, but the real one will be a .dll file instead. I have to export the grabbed arrays of pixel values to the created .dll file. The only thing I have done so far, is building the .dll file, so what is the next step ?.
Best regards
Oesen
Message 5 of 8
(3,695 Views)
You'll need to rebuild the DLL and retest it once you get rid of the while loop and stop button.
Message 6 of 8
(3,678 Views)
What is the problem with the while loop actually ?
Best regards
Oesen
Message 7 of 8
(3,669 Views)
When it's a dll, how would you stop it without the front panel? I it's removed when it's built.
Message 8 of 8
(3,659 Views)
