exporting control names
I have created a control cluster with a series of string controls in it.
I would like to use the labels of each of the controls as a header for a file. Is there a property node or a method to extract this information?
I could unbundle by name, create an indicator for each item and get the text label property node for each item, but I was hoping for an automatic method so if I add/remove controls to the cluster, it will automatically extract/ignore the extra/deleted header .
Pablo
Message Edited by Manc Pablo on 09-03-2008 10:24 AM
"When I read about the horrors of drinking, I gave up reading"
(2,949 Views)
the Controls[ ] property of a cluster gives you an array of it's contained controls' references.  you can also use the controls[ ] property of a VI's front panel to do the same thing for a whole VI.
Message Edited by JeffOverton on 09-03-2008 11:28 AM
(2,945 Views)
Brilliant, Excellent, Genius!
I am off to the pub!
(2,940 Views)
