export to clipboard returns only integer
Hi ,
I've seen a stange data ouput when I use the "Export Data to Excel" function on a Graph indicator.
Using the VI in attachment I can simulate some data. After that I right clicked the graph and try to read the data in Excel.
However That is what I got in Excel:
But the 2 and 4 Column should be double but I got the data in Excel seemingly in the form of integer.
How does it comes and how can I get the original double values?
Wilbur
(2,398 Views)
You are right, this is incorrect behaviour.
I filed a CAR - Corrective Action Request reference number #399104.
If fixed in a later version you will find this number listed in the fixes.
meanwhile you can work around using a "write to ascii file" function with the Data you are writing.
(2,362 Views)
