export from ring control
Is it possible to export the list of items in a ring control or conversely import a list into a ring control?
Jim
LV 2020
(4,392 Views)
PropertyNode ?
(4,389 Views)
As nyc said, either of these properties will extract the strings from your ring
(4,370 Views)
Yes, you can read it that way, but not write.
Jim
LV 2020
(4,341 Views)
With rings you can write it that way, by property node, even at run-time.  Enums you can't write at run-time Rings and combo boxes you can.  Some minor points but well worth knowing.Smiley Wink
"Should be" isn't "Is" -Jay
(4,335 Views)
As said previously...
(4,334 Views)
Sorry, I wrote this VI a long time ago. The label says ring but it is an enum.
Jim
LV 2020
(4,321 Views)
