explanation
Hey Gerd
I didn't saw your first message sorry . 25 in/ out are too much ?!!!! OH my ... and that's only 2 Axes of 4 ... II was trying to understand what you wrote in your mail, I  didn't understand everything . if you open the LV you will notice that I am a beginner , I have been working on this LV for 2 month , and this is my first LV ever
so If you can give me an idea or an advice , I will be glad to hear it
Toni
Message 11 of 15
(737 Views)
Hi Toni,
thanks for uploading the sources.
At the moment I'm busy in the lab having no time for editing your vis, so it will take some time... But from a short look I can state a slight overuse of sequence structures!
Also you can try to connect an error cluster directly to a case structure (without any unbundle function in between) - be surprised to see what happens!
Message 12 of 15
(727 Views)
Hi Toni,
I tried to clean up your vi a little bit - but a lot of subvis are missing...
I also couldn't find anything mentioned in your earlier posts (EndPosition1&2), so where is your problem in wiring this?
Message 13 of 15
(701 Views)
Hi Gerd
thank you very much for every things....
I solved the problem but before allow me to tell you how my LV works.
the LV is in While-Loop and it works till I press the Stop button and that what i want to avoid . i want that the LV stops running automaticaly after the axis moves from A to B and than from B to A (home Position)
that's why I wanted to add that funktion and I didn't know how to do it , so I have choosen another way, using the Boolean , which are in the SubVI (select&Move), by the way in this SubVI you will find the EndPosition1 & 2 , and the Boolean turns on when he goes back at home position. So I add this  funktion : IF(boolean1 ON & Boolean2 ON Stop running and it's working till now ( see Pic)
once again thank you
Toni
Message 14 of 15
(692 Views)
Hi Toni,
nice you found out the way to reach your goal.
And thanks for the pic, as for me the subvi was missing...
Message 15 of 15
(683 Views)
