expire loop delay
I need to expire a loop delay timer that has a long interval (roughly 5 minutes or more) so the user can stop the application using the UI and not have to wait 5 minutes for the timer to expire. Any ideas? Thanks ahead of time for your response.
I could use a "Halt" but this will not let the loop complete the final cycle and properly stop.
(2,861 Views)
Place your code inside the loop in an event structure with a timeout of your desired loop delay. Now add a second event to break it. 🙂
(2,855 Views)
That worked out just fine. I had totally forgotten about the event timer and thats why I asked of course.
Btw, I put a case structure in the event to "pause/run" my time-out case.
cheers,
richjoh
(2,836 Views)
