execution priority for application
The executable of my application doesn't reflect the priority I set in VI Properties (Win XP). Is there an .ini setting I can make to have the exe run at background priority (lowest)?
(4,150 Views)
Also, the name of the exe is ftp_aigo.exe
I tried putting this in the .ini file but it has no effect:
[ftp_aigo]
ESys.Bgrnd=True
Do i need to explicitly set the open config and readkey in the exe, and if so where do I write the value to?
Thanks for any help,
Paul.S
(4,150 Views)
You may want to take a look at this. Setting the priority within the options of LabVIEW will not affect its priority within XP. LabVIEW is given priority when it starts running on XP. You can programmatically call an XP DLL and make it give you higher priority. This KnowledgeBase on NI's website describes how to do that.
J.R. Allen
(4,150 Views)
Thanks JRA, that looks like what I want
Paul.S
(4,150 Views)
The documents mentioned have been updated and moved to Developer Zone at:
Program Process Priorities in Windows
http://zone.ni.com/devzone/cda/tut/p/id/6871
John H
(3,830 Views)
