execution glyph
Hello LabVIEWers...
When I pause the execution of my labview code, I get an "execution glyph" (see attached screen-shot) on the block that seems to be causing the program to stop. What does it mean?
(4,067 Views)
That means that your code is still running within that subVI. Open the subVI to see what's holding it up.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(4,064 Views)
It means that that subVI is still executing and has not completed yet. Maybe you can open its diagram and see what it is doing and where it is stuck.
Who wrote the subVI?
(4,062 Views)
