execute case structure only once
Hi everybody.
I want to execute a case structure inside a while loop only once. The case strucutre is controlled by a counter, so that every time the counter has a value multiple of N, the program records an acoustic signal and calculate the main peaks of the FFT. The problem I have at the moment is that, every time the case is executed, it records and analyze the sound several times until the counter jumps to the next value. I want the case to execute only once every time the counter has a value multiple of N. I atttach the vi.
Thank you for your attention guys!!!
Message 1 of 13
(6,872 Views)
Hi Franky,
right now the case structure is called with
IF counter = zero
You should change that to
IF (counter = zero AND counter <> previous counter value)
Btw.  there are special functions to compare for "=0". There is also a function to convert a boolean to 0/1.
Message 2 of 13
(6,860 Views)
GERD is right.  You should use a feedback node to store the previous count value.  If the current count is Not Equal AND the remainder is Equal To Zero run your case.
Since your counts are all integers, I would also recommend changing the representation to an integer type.  I32 would likely be the most appropriate.
Message 3 of 13
(6,852 Views)
Already solved! Thank you guys!!
Message 4 of 13
(6,833 Views)
Hey, I'm new to Labview. Im facing the same problem.Please can you show me how to do what you have suggested?
Message 5 of 13
(6,034 Views)
Hi amysri,
I'm new to Labview.
Yes, you even don't know how to spell/write "LabVIEW"… 😄
Did you notice that "beginner" (aka "Tutorials") section in the header of the LabVIEW board?
This forum works the other way around!
Show us what you have tried so far and tell us, where you are stuck!
As has been said several years ago: you will need two comparison functions and a shift register (or feedback node) to reach your goal!
Message 6 of 13
(6,025 Views)
Message 7 of 13
(6,011 Views)
Hi crossrulz
Thank you so much.. 🙂
It means a lot
Message 8 of 13
(6,007 Views)
It means a lot
Funny, I don't see any "thank yous".
Message 9 of 13
(6,000 Views)
My first post begins with an apology...to crossrulz for incorrect posting etiquette and probably a ton of other forum transgressions, but a POST button is missing for some reason and I have been researching and fiddling around for days on how to execute a case structure only once.  I finished Core 1, working on Core 2, but am still practicing on actual coding, so would appreciate really dumbed-down help.
Specifically, how can each of the case structures in the attached pic be programmed to execute once?  Others have suggested local variables, "implies statements", First Call?, Shift Registers, but am not sure how to implement them
Thanks for any direction.
Message 10 of 13
(5,744 Views)
