executable display settings
I've posted something similar to this before and even called National Apps.
DISPLAY/MONITOR SETTINGS!!!!
I created a vi w the Development SW then an exe ( using Project) and ported it to the target machine...no sytax errors, runs like a charm.  After a number of iterations w National it was determined that my display resolution was different from one machine to another.  So I chg'd them to match...developmnt= target resolution.  I'm still running into issues.  Under "VI Properties>window appearance "  I left it as default.  "VI Properties>window size " I left it as min panel width 0 and 0.  Maintain portions... and Scale all... I left unchecked.  Under " VI Properties>window run time position " I left as Position unchanged..  When I run the exe on the target machine some of the front panel controls are skewed slightly to the right.  I can see almost 1/3 of the screen to the left is the front panel that was blank in the source file even though when  I saved it and created the exe, it was centered on my develop machine.  I have buttons that select subvis and when those are called some of them are as if I had hit the "Restore down" button in the upper right of the window.  They're not max.  These were all at the recommendation of the App Engr.
Is there a process to get the target vi ( and all subvis)  to run centered in the display and "maximized" when the user calls it on the target machine w/o having him or her chg the setting each time???
(2,700 Views)
These links may be of help.
https://decibel.ni.com/content/docs/DOC-8643
http://zone.ni.com/devzone/cda/epd/p/id/2401
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
(2,698 Views)
