executable build close when stop
I am building an executable application. When the  application ends, it remains in an open window that needs to be closed separately afterwards. Is there  a way for that window to close automatically when the application ends?
(3,859 Views)
Under application control there is a VI called Quit LabVIEW.  That should do the trick.
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,854 Views)
But you should wire the Application>>Kind property into a case structure to only run this VI when you are in an EXE.
___________________
Try to take over the world!
(3,844 Views)
Thanks for the extra info about Kind property.  I couldn't figure out how to do it even though I know it was possible.
Matt
Matthew Fitzsimons
(3,829 Views)
Attached is a VI I wrote which I use for this. Note that it only exits if it was called by the top level VI. The reason I did this is because I sometimes take working programs and call them from other VIs. This allows closing them without stopping the EXE. I haven't really checked how this works with dynamic calls.
___________________
(3,810 Views)
