excel
Hello Guys
I need a help please, i'm working in a test bentch and i have several large excell spreadsheets of data and i need to merge into one spreadsheet using labview. Can anyone tell's me how to do it?
Thanks, Hugs
(4,011 Views)
Hi Rui,
you need to read each of your "several excel spreadsheets" and then save the data in "one big spreadsheet". Sounds pretty straight-forward…
What exactly is the problem? Where are you stuck?
(4,007 Views)
Hello GerdW
I'm stuck because i never did it before and i work in labview for one year. i'll try to do has you told. If you send me an example, i appreciate it.
Thanks a lot
(4,002 Views)
Hi Rui,
when you use the RGT (ReportGenerationToolkit) you will have a lot of examples in the LabVIEW example finder.
Try those!
(3,993 Views)
Here is an example using the Report Generation Toolkit that I posted about a year ago ...
(3,958 Views)
