excel to xml to labview
DSarge,
You posted links to the ae.natinst.com server.  They are only visible to NI employees.
You need to post the links that are accesible by the public.
Message 11 of 23
(1,966 Views)
Apologies. Try these two, they should be the public links.
http://digital.ni.com/public.nsf/allkb/EA451498B828894886256F67007AE6B9?OpenDocumen t
http://digital.ni.com/public.nsf/allkb/3E1759E53173D8BD862573D200686E20?OpenDocument
Message 12 of 23
(1,959 Views)
I am working with Labview, not CVI which makes the first link N/A.  The secondlink says  "LabVIEW has built-in XML tools that can be used to work with schemas, manipulate XML data, and perform XML parsing."
I do not see the ability of Labview to work with schemas from external sources.  I only see the way Labview works with its own schema.  Any thoughts??
Message 13 of 23
(1,942 Views)
I have the same problem.
Maybe can we read the data thru a .net method exposed by excel ?
(supposing excel is installed on the PC)
BR
Message 14 of 23
(1,918 Views)
LabVIEW's flatten to and unflatten from string functions will work with the LabVIEW XML schema. To use a different XML schema in LabVIEW, you will need to parse the XML. This NI white paper has some more information:
https://www.ni.com/docs/en-US/bundle/labview/page/parsing-xml-files-in-labview.html
Let me know if this helps!
David R
Systems Engineer
Message 15 of 23
(1,894 Views)
@id wrote:
what I have is an excel SS to enter engineering data as a starting point.  What I want to do though is to have an XML file as the datafile that is stored as a part of the program for life cycle sustainment that is read into the Labview program. My challenge is that Excel does not write an XML file based on a labview schema.
The much easier way is to save the Excel file as a comma or tab separated text file. 🙂
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 16 of 23
(1,881 Views)
actually, I used ActiveX functions, it seems to work quite well. Some tuning may be required...
Phil
Message 17 of 23
(1,881 Views)
thanks but I seem to have errors if I save my file in excel to either an xml ss or an xml format still.  What are you saving your file in excel to in terms of teh excel dialogs?
Message 18 of 23
(1,874 Views)
I don't use excel to save my file, it is created by a measuring device directly into xml format.
Maybe try to use the open method in lieu of the openxml methode ...
Phil
Message 19 of 23
(1,870 Views)
Is it a requirement that those Excel files be saved as an XML file? If it were me, I'd save them as a comma-delimited text file as Yamaeda suggested.
Message 20 of 23
(1,858 Views)
