excel time string
i've got a problem with an Excel import. One cell is a date like 07.2.2008.
LV reads it a string array with 39485 for the date.
Is it possible to transform it back to the date?
Markus
(4,110 Views)
Hi John,
Excel stores dates (usually) as number of days since 01.01.1900 - hence 39485 is 07.02.2008.
You can do two things:
1) switch excel to use the 01.01.1904 as start date (like LabView does)
2) subtract the offset of 4 years (number of days=1462) from the Excel date number (39485-1462)
Then you have to multiply the resulting number by 86400 (seconds per day), this can be wired to the LabView time functions...
Message Edited by GerdW on 02-18-2008 12:59 PM
(4,100 Views)
Hi GerdW
as always the real good answers can be found in the LabView discussion forum - thanks a lot !
regards HU
(3,946 Views)
