excel sheet sheets save
     I'm using Report generation tool kit(LabVIEW 2009) to generate excel sheets for my application.suppose I have 20 modules of same type,then I've to generate 20 different excel sheets and want to save those with different serial numbers in a folder and my front panel should have the option that if I press the serial number the corresponding excel sheet should be opened.How can I go about it.see the attached code for reference
Regards
RobinHood
Message 1 of 8
(3,879 Views)
Can you also post a screen shot?
Message 2 of 8
(3,875 Views)
see this code
Regards
RobinHood
Message 3 of 8
(3,866 Views)
The reason why asked you post the code is  iam still stuck with 8.0.
Message 4 of 8
(3,859 Views)
Regards
RobinHood
Message 5 of 8
(3,857 Views)
        I'm saving each and every excel sheet I'm generating with a different name.  But I'm forced to provide .xls in the
name of the excel sheet on the front panel. This is not user friendly. I want to write the name of the excel sheet only,
but not the extension(.xls) on the front panel. I want to put the extension in the block diagram as a constant and the
user will not have to specify the .xls on the front panel but just the name of the sheet(with out .xls extension on the front
panel).How can I go about it.
Message Edited by Robin Hood on 03-11-2010 11:14 PM
Regards
RobinHood
Message 6 of 8
(3,831 Views)
You can concatenate a string constant with ".xls" to the string control before passing it into the build path function.
Message 7 of 8
(3,826 Views)
Thanks Raven.
Regards
RobinHood
Message 8 of 8
(3,824 Views)
