excel sheet generation
Hi
     I want to generate Serial number and Frequency values in an Excel sheet.But I am getting the serial no and Frequency names at the bottom and the values at the top. I've attached the vi here.Please find it.I want the S.NO and Frequency at the top and values underrespective headers.
Regards
RobinHood
(2,897 Views)
Accepted by topic author Robin Hood
hi vipul,
the code is been edditted its working as u wanted as u were using the set order in the loop it was rearranging the data and header as well so u were getting the header at last,
now the start value is getting incremented each time and so there is no need to set the order in the loop,so for ur reference without deleting the set order.vi i have used a false case and made it as a dead vi u can remove the set order.vi once u go through the code. i am attaching the modified code its working as u wanted.
(2,879 Views)
Hi Raghu
               Thank you very much for your help.
Regards
RobinHood
(2,859 Views)
