excel add-ins
I've got a problem with the add-in function for excel. I'm able to open an excel workbook thru ActiveX and transfer data into the worksheets. However, I'm not able to view my DPlot add-in. The add-in box for DPlot is enabled in the Tools->Add-ins... If I disable that, go OK, then go back into Tools->Add-ins... again to re-enable the DPlot box, it's available.
If I run excel the normal way (ie not thru Labview), my add-in is visible straight away.
Does Labview disable some add-ins? Is there a way to keep the add-ins always enabled and available?
I'm using Labview 7 and Excel 2003.
(5,119 Views)
Hi flai,
LabVIEW does not disable any add-ons from Microsoft Excel. Can you explain a bit more about what LabVIEW is actually doing and what you expect it to do? Maybe you could post a screenshot of the block diagram so that we can see how you have things setup. Also, there is another discussion forum post with a similar issue that has some links to other resources as well.
(5,088 Views)
Hi CarlaU,
I have written a vi to update/transfer data from table format into an excel spreadsheet when the vi is run.
If I run Excel on its own (Not via Labview), the add-in command DPlot appears in the top Toolbar section.
When Excel is opened up by this vi, the add-ins that have been installed (and running properly) cannot be seen on the toolbar.
However if I run the following macro in the vi  (as shown in the vi diagram above) :
    Sub add_in()
       AddIns("DPlot Interface").Installed = True
    End Sub
in the beginning of the vi to 'enable' the add-in and then when i want to quit, I run the next macro :
    Sub add_out()
       AddIns("DPlot Interface").Installed = False
    End Sub
at the end of the same vi, everything works perfectly. I thought that opening Excel via Labview should automatically run all add-ins that have already been installed into Excel previously. Is there a way to have the add-in command always there without the hassle of turning it on and off? Cheers!
(5,067 Views)
Hi flai,
Thanks for the information. Have you tried to implement the property nodes and methods for AddIns?  There is an object AddIn in the property node of "_Excel.Application" and you can invoke a method "Add Excel.AddIns", which has a file name as an input. Maybe trying to implement these into your code can help bring up the Add-ons in excel at startup. I hope that helps a bit!
(5,032 Views)
I had the same problem with an add-in that was called upon opening a workbook.
I could solve it by after opening excel, call the addin property of the application, take a reference to the add-in that was needed (using its name) and then by setting the "Installed" property of the add-in first OF and then ON! It did not work just setting it on, it had to be set off first!
In the attachement there is a (non working) via wich shows the code I inserted in the "New Report" vi from the Office toolkit addon of LabView.
I am usingLabView 8.5 and excel 2003 SP3
(4,957 Views)
