example for multicard reading
hello,
i' ve got an project where i had to measure many channels from different cards.
every card should be activated and configurated on the frontpanel by the user.
is there an example in lv how to solve the problem?
markus
(2,649 Views)
Hi Marcus,
You can go to LV Examples/Hardware Input and Output/DAQmx/Synchronization/Multi-device/Multi-Device synch cont Acquisition.vi. This uses two DAQ cards with synchronisation. If you don't wan't the measurement to be syncd, you can simply delete the case structure.
Hope it helps
KAliDas
(2,644 Views)
