example finder favorites
When I go into the Help utility I can search and find various items and then when I find an item that I will want to go back to it is a simple thing to add the item to the favorites menu and all is as expected when I look in the favorites tab!  However, when I go into the example finder tool I can brouse and search for various VI according to what I am looking for and again all is well and good. However, I noticed that when a particular example VI is selected, the add  to favorites button is enabled, so I clicked it and added the VI to a favorites list. Once the VI had been added to the favorites a remove from favorites button becomes visible. The example finder has no favorites tab! How do I go into the favorites section and see what I have added to the favorites!
(2,609 Views)
Accepted by topic author hounddog
When you add favorites to NI Example Finder, this creates a "Favorites" folder where you can quickly access the VIs you have chosen.  This folder is in the list of Folders located in the "Browse" tab while inside NI Example Finder.  I've added a screenshot just for illustrative purposes.
I hope this helps!
Daniel Dorroh
(2,577 Views)
