examining block diagram- ports on VI- How do I determine which port is wired
Trying to figure out how a block diagram is wired with a a vi that has lots of ports.  Is there a way that I can identify where the wire goes on the vi?
(2,770 Views)
Hi kevinG,
what do you mean with ports? If you double click the wire, the entire wire is selected and you can see it better.
Hope it helps.
Mike
(2,768 Views)
Hi keving,
                Can you post a screen shot to explain your query?
(2,762 Views)
MikeS81 wrote:
If you double click the wire, the entire wire is selected.
Triple click. Double clicking only selects the wire section you clicked.
You can also right click and wire and choose to clean it up, or if you're using 8.6, use the automatic diagram cleanup feature.
___________________
Try to take over the world!
(2,741 Views)
As tst said, you can triple click to see the entire wire.  Some people don't wire properly, with wires going underneath objects.  If you look closely at the attached picture, you can see the highlited wire (the one surrounded by dash lines) goes to the top right corner of the object it is wire to.
Wire
Message Edited by tbob on 08-21-2008 12:30 PM
- tbob
Inventor of the WORM Global
(2,718 Views)
