every nth point
Hi
Further to my question a couple of weeks ago, about calculating a
running averaging using the last 20 data points acquired, I now need
to find a way to cut down the amount of data that is subsequently
plotted/saved.
Now the data has been smoothed, I only need to save down every 5th
point (or so). I am taking data at such a quick rate (in order for the
smoothing to work effectively, without "rubbing out" the signals which
I am actually interested in), and I do not want to end up with data
files which contain a massive number of points.
Could anyone let me in on a way to pluck out every "nth" point of my
running average?
Thanks in advance
Jon Atkinson
(3,364 Views)
If your data is inside a 1-dimensional array, you can use the function "Decimate 1D Array", located in:
Diagram palette -> Array
This function does exactly what you are asking for.
Regards;
EJV
www.vartortech.com
(3,364 Views)
Hi
So it does! Thanks very much
Jon
"Enrique" wrote in message
news:506500000005000000572F0000-991728092000@quiq.com...
> Regards;
> EJV
(3,364 Views)
