event structure
Hi, I have two events in a event structure. I need to use one event to input "yes" to a boolean indicator and use the other event to inpot "no" to the same boolean indicator. How to do that? The Labview help is helpless.
Message 1 of 9
(3,965 Views)
Use a local variable.
@Jerry Jin wrote:
[...] The Labview help is helpless.
Definitely not. It may take some time until it becomes your friend.
Message 2 of 9
(3,961 Views)
Like this?
Message 3 of 9
(3,960 Views)
I'm a bit confused by the idea of a boolean with values Yes an No so I assume you meant property.text
Here's a quick example that demonstrates the event structure
"Should be" isn't "Is" -Jay
Message 4 of 9
(3,957 Views)
@WayneS1324 wrote:
Like this?
Wayne!  Hold up on that- event structures without a loop are pretty dangerous. The events can queue up pretty fast waiting for an active event loop.  And we won't use the run continusly button outside of code testing again!
With a while loop thats a nice example
Message 5 of 9
(3,950 Views)
@Jeff Bohrer wrote:
@WayneS1324 wrote:
Like this?
Yeah, I know. It was just meant as the simplest possible example of an event structure. I guess it was a bad example.
Message 6 of 9
(3,945 Views)
Could you save the VI as LABVIEW 2009 version so I can open it?
Message 7 of 9
(3,934 Views)
Accepted by topic author Jerry Jin
Here you are-
Message 8 of 9
(3,926 Views)
Hey, I'd really love to get the same for LV 7.0 Smiley Happy
Would be really great!
Thanks in advance,
logi
Lv 7.0 Sudent Edt. Mac OsX 10.6.8/10.7.2 Windows XP
Message 9 of 9
(3,870 Views)
