event structure, remove and default
Two questions:
1. Can the event structure (6.1) be removed like the other structures
without deleting the stuff inside? I didn't see it on the right-click menu
so I just replaced with a while loop and then removed the while loop in two
steps. You can delete individual cases but not the structure as far as I
could see.
2. On an event structure an output is allowed to "Use default if unwired"
but I am not quite sure how to specify the default value. I didn't see a
default in the edit events list. Hints?
-joey
(3,087 Views)
1. The next version of Labview will probably have the "Remove Event Structure" option you desire. Hopefully it's not too inconvenient to use the two-step method for now.
2. LabVIEW does not offer an option to change the default values for structure output tunnels. The following default values are set for these data types:
Boolean: False
Numeric: 0
String: Empty String
VISA Channel Strings: Empty String
An array or cluster will return an array or cluster with the default values of the data types in the array or cluster.
Bryan Dickey
http://www.ni.com/support
(3,087 Views)
