event help
Hello.
When i try change y value in my vi my theta value is going 0 (default).
Theta change value event is ok. But i need help y value change.
My files on attachment.
Thanks.
(3,428 Views)
Accepted by topic author keremgeliz
The theta value does not go to zero. However, when you change y you use the original image array rather than the rotated array.  I think you need to feed the left shift register terminals to the event structure for the image and boolean data.  In the image below the arraos show the original connections.
Lynn
(3,389 Views)
Hi Lynn. Its working
Thank You
(3,366 Views)
