event-driven and process time
I have a event driven VI that has an SUB-VI in each event case.  There is a timer in the sub VI.  When I run the sub VI faster from 500ms to 1 ms the process time goes up even when the subVI is not running.  What I expected was very low CPU time until the subVI ran but this is not what happened.  I guess I do not under stand the event-driven VI.  Is there a document I could read on this?
DonRon
(3,022 Views)
The CPU usage should not go up unless the subVI is running, and it didn't go up when I tested it. Even if the subVI is running, it should probably not go up much unless you put 0 in the wait or delete the wait.
I'm not sure what you're seeing, but I'm not seeing it. Could you post a screenshot of this, or list exact steps for how to recreate it?
To learn more about LabVIEW, I suggest you try searching this site and google for LabVIEW tutorials. Here and here are a couple you can start with. You can also contact your local NI office and join one of their courses.
In addition, I suggest you read the LabVIEW style guide and the LabVIEW user manual (Help>>Search the LabVIEW Bookshelf). The user manual also includes a chapter about events. You can also try searching the site for specific tutorials about event handling.
___________________
Try to take over the world!
(3,014 Views)
I concur. I saw absolutely no change in CPU usage when I ran the example. The only change I saw was when the subVI started and then it dropped right back to where it had been.
(3,006 Views)
Don Here,
Sorry, I just ran it again and it acts like the way you say.
DonRon
(2,982 Views)
