event callback insanity ????
I have a operator interface that executes TestStand. Some of the other code was written before I arrived to help these people. Occasionally my operator interface will lock up. Debug mode shows it is still running but I can not select menu items or change controls. Occasionally I get a fault which aborts LabVIEW. Here is the dump
#Date: Mon, Jan 26, 2004 2:46:01 PM
#OSName: Windows NT
#OSVers: 5.0
#AppName: LabVIEW
#Version: 7.0
#AppKind: FDS
D:\lvworm\src\lvsource\eventoracle.cpp(370) : DAbort: event callback insanity
$Id: //labview/branches/Wormhole/dev/lvsource/eventoracle.cpp#112 $
0x00589B50 - LabVIEW + 0
0x0058A245 - LabVIEW + 0
0x0058CFDB - LabVIEW + 0
0x0040AF57 - LabVIEW
> + 0
0x0C3EA9C7 - tsui + 0
0x0C3E9FC3 - tsui + 0
0x0C3E1FEF - tsui + 0
0x581777B0 - teapi + 0
0x77E3A2D0 - USER32 EnumClipboardFormats + 76F
0x77E145E5 - USER32 GetDlgCtrlID + 1E
0x77E15B51 - USER32 wvsprintfW + 132
0x00B84CA0 - LabVIEW + 0
0x00B3C46B - LabVIEW + 0
0x00C0813C - LabVIEW + 0
0x7C5987E7 - KERNEL32 SetLocalTime + 4FC
Any ideas on what might be causing at least the problem that the dump list?
(3,017 Views)
This sounds like one of those auto generated error log. You can send those to NI by launching LabVIEW >> help >> invesitgate internal error. There is a small chance that this error has already been reported and that a solution exists.
(3,017 Views)
