ethernet ping
is there a way to use Labview to ping another ethernet card in the same
computer without getting short circuited by windows. the ping needs to
go out to a remote device and then back to the second ethernet card.
any suggestions without having to use two separate computers?
thanks in advance
tim hemmis
(4,993 Views)
What exactly are you trying to do? If you are checking to see if both NICs are working and configured correctly you can use the "ipconfig /all" command line (system exec VI) to get the IP addresses and other connection related info from Windows. Why do you want a ping request to go "through" a remote device? Is the device a router? Are you checking to see if it is routing correctly? If not, then there is likely an easy way to get the answer to your "real" question.
-Jim
(4,993 Views)
Jim,
we are trying to test some devices that convert the ethernet info into
RF, pick up the RF at another unit that converts it back to ethernet.
if we set up another computer at the other end we can test the units
okay. i was hoping to cut expenses by combining the NIC cards into one
computer and send the ethernet info out to the devices and return the
data to the other NIC card, but Windows short circuits the path within
the computer.
thanks,
Tim
> t
> -Jim
(4,993 Views)
What version of Windows are you using?
-Jim
(4,993 Views)
WinNT ver 4.0
tim
> -Jim
(4,993 Views)
I don't think this is possible. Mainly because ARP will resolve the
addresses and recognize its two IPs in the same machine. You have to hit
something outside then send it back (ie., router, another computer).
Jim
> thanks in advance
> tim hemmis
(4,993 Views)
Try to use e.g. "traceroute" (hopefully "tracert" in Windows)instead of ping. This should work depending on your ethernet device capabilities and protocols used.
Ping is for ECHO requests between TWO ethernet points.
Sergey
(4,993 Views)
