escape character xml
Dear all,
I wrote some VIs to deal with xml files.
In particular I have one VI to write the xml and another one to read it back, after validating it.
Unfortunately
got translated like this
which creates of course errors while parsing the xml file.
It looks like the ":" needs to be escaped...
Does anyone have any idea?
Many thanks in advance,
Marco
PS I really would like to 'attach' VIs and xml, but I click 'Add Attachments' and nothing happens... maybe it's ok, it's my first post here <:-)
(3,575 Views)
So, xml got wiped out...
In attachment (now many buttons apperead) you find:
  1. the run_write_config.vi VI
The vi produces the xml file as output
The point is that you get the xml without ":" at the 2nd and 3rd line:  ":"  in "xmlns:xsi" and "xsi:noNamespaceSchemaLocation" (second and third line)
Again, any help is welcomed!
             Marco Bomben
(3,571 Views)
It appears that you are using JKI's Easy XML library. You'll probably get a faster response if you post over at JKI's support forum for that library.
(3,554 Views)
Yes, you're right. I will post there.
Many thanks,
                     Marco
(3,529 Views)
(3,525 Views)
