errors when Math Interface Toolkit creates dll
Dear NI experts.
When I want to use Labview Math Interface Toolkit  to create a simplest DLL, I got errors(see attachment), I can not get the dll file.
My vi is just like y=x+1.
My operating system is : WinXP sp2
Labview : Professional Development System, Labview 8
Math Interface Toolkit : don't know the version, just download from NI on 30 June 2006.
Looking forward of reply soon.
Many thanks
(2,965 Views)
Hi Z
Please make sure that you have version 1.0.2 of the math interface tool kit as version 1 is not fully compatible with LabVIEW 8 you can check what version you have if you got to start>>control panel>> Add Remove programs >>National Instruments>>change look for Math Interface Toolkit XX.
Here is a link to check what version of the tool kit you need for different versions of LabVIEW
http://www.ni.com/support/labview/lvtool.htm#math
I have added a link witch deals with some of errors that might occur while using math scrip it also has some useful additional links at the bottom of the page
Error When Calling a MEX File Created With the Math Interface Toolkithttp://digital.ni.com/public.nsf/websearch/55708A4952BDD4A386256E85005720B4
I hope this helps
Tim
Applications Engineer | National Instruments | UK & Ireland
(2,940 Views)
