errorin and errorout to/from .NET
How do I pass errorin and errorout clusters to and from
a .net program in c++ or c#
(2,740 Views)
Why do you want to do this? Are you talking about passing to a call library node or will you be using the .net constructor in LabVIEW 7?
The error cluster is just a cluster so you might consider unbundling it into a boolean, numeric, and string and passing it that way.
(2,740 Views)
