error
Hi all :
Can any one please help me with this error what its mean:
does the meaning of it error in my application ?
or its international error :
some one answer and told that its Most of the time caused by illegal calls to DLLs. Yes I am using some dll but how can I locate this error ,, some time this error appears when I press on stop bottom ,,,  some time it appears in the middle of running , and some time at the end ,,,, how I solve this problem ???
,, when this massage appears labview don't make my any choice just shutdown immediately, so i can't know from where the error come
Please help
(2,802 Views)
See here
My LabVIEW Ideas
(2,797 Views)
Hi:
I saw you answer but my question is how to investigate when this error happens,, as i told laview shutdown as soon as this error appears
thanks
(2,794 Views)
Hi elyan,
don't create new threads when you ask the same question again!
You can do:
- write a logfile in your vi. Every (important) step is noted in the logfile. You can read the logfile after LV crashed...
- show what you do in a string indicator - same as above: you will read at which point you crash before you quit that Microsoft dialog...
- remove suspicious vis until LV doesn't crash anymore - now you know the reason...
Message Edited by GerdW on 03-05-2008 03:30 PM
(2,784 Views)
