error while using a third party card in labview RT
i am using a PC as a RT target, and the third party card in this pc is PCI6208 supplyed by ADLink.
when i deploy my program from another PC in windowXP system to this one,the problem comes: the program can't run if i add any module supplyed by ADlink(AO module for example). if i remove these module, the program can run.
there is also another problem: I can't run my program on this RT target if I just deploy my project. That means I have to build a real application and set it as startup, and then restart the target. Only in this condition can my program run.
Could someone give me some advices?Does the LabviewRT unsupport my ADlink card,or is there any other reason?
Message 1 of 1
(2,328 Views)
