error when trying to use DO as "open collector" on PXI-6602
When I try to configure a DO of my PXI-6602 as "open collector" I receive the error -200452 ("Measurements: Specified property is not supported by the device or is not applicable to the task."). This is completely mysterious to me since the PXI-6602 should have this feature and my code (see attachment) is practically identical to any of the numerous examples for this topic. Am I overlooking anything really stupid? (LV 8.5, PXI-8145RT) Cheers, uli
(2,656 Views)
(2,629 Views)
Accepted by topic author uli82*
Hi uli82*,
The error message is correct. The PXI-6602 does not support the DO.OutputDriveType property. If you want to set the PXI-6602's DIO lines to a high-impedance state, use the DO.Tristate property or create a digital input channel.
Configuring a DIO line's drive type as open collector would cause writing a 0 to drive the line to 0 V and would cause writing a 1 to tristate the line. If this is the behavior you want, you'll have to emulate it using the DO.Tristate property.
Brad
Brad Keryan
NI R&D
(2,616 Views)
Hey Brad,
thanks for you help. I think what you are suggesting should work. As I get it in the tristate both of the push-pull-MOSFETS of the DO are open, so the DO goes to a high impedance state. However, I cannot set this property while the task is running. And then I would have to worry about the state of this output before I set the property and so on. Here is my preferred solution. One can just connect the DO to the gate of a MOSFET, the drain to ground and then use the source as the output. voilà.
uli
P.S. Am I the only one that is misinterpreting the NI specs for these PXI cards that say "Output Current Flow Sinking, Sourcing"
(2,609 Views)
Hi uli,
Did you try setting DO.Tristate while the task is running? There are a few DAQmx devices that do not support setting DO.Tristate while the task is running, but I don't think that the PXI-6602 is among them. I don't have an actual 6602 installed but with a simulated PXI-6602 and DAQmx 8.9, setting DO.Tristate while the task is running does not error.
Using external hardware is perfectly fine, and should also work for timing I/O (whereas using DO.Tristate would only work for single-point digital I/O).
I don't see the text that you quoted in the NI 660x Specifications, so I don't know what context it was in, and apparently it has been reworded since then. Note that devices that support open collector output say "open collector (open-drain)" in their specifications; for an example, see the NI USB-6008/6009 User Guide and Specifications.
Brad
Brad Keryan
NI R&D
(2,605 Views)
