error using database toolkit
hello, i am getting error on inserting data to sql database, using data base toolkit, before i was using same method only that time it was working well.
find this attachment.
Balaji DP
(3,279 Views)
I see you use a To Variant node to cast your cluster to variant before wiring into the input data. Don't do that. You can directly wire your cluster to the input data. You can try that. Could you post your VI if still not work? Remember to remove your confidential code if there is.
(3,235 Views)
I added my thought on the other thread - http://forums.ni.com/ni/board/message?board.id=170&message.id=417531#M417531
Jim
(3,217 Views)
hello,
               i just re-installed my toolkit then its started working...... i dont know now they days ni supports are getting tooo late.....
Balaji DP
(3,214 Views)
